CSS Form builder is generating the error code
Thread began 1/05/2010 10:12 am by kofiwurah139923 | Last modified 1/05/2010 6:39 pm by Eric Mittman | 1089 views | 1 replies |
kofiwurah139923
CSS Form builder is generating the error code below during the processing of a form and does not complete.
"Adobe Dreamweaver CS3 has encountered a problem and needs to close. We are sorry for the inconvenience."
Help help asap
You should try deleting your cache file to see if it clears up this issue. Here is a link to our document that details how to do this.
If you continue to have the problem there may be a corruption of your configuration folder. Here is a post that details how you can rename the folder to get past any problems associated with it:
showpost.php?p=12293&postcount=2
Let us know if you continue to experience this problem after trying these things.
