Remove WebAssist tags from site?
Thread began 1/02/2010 1:12 pm by markymark44 | Last modified 1/04/2010 2:06 pm by Jimmy Wu | 1058 views | 6 replies |
markymark44
Can I remove this line of copy from the entire site? {Copyright 2009 © PHP Scripts powered by WebAssist.} Any help would be appreciated...
Office Guy-172461
I'm not aware of any issue with removing the line.
Here's an example of the customization someone on the forums did to PowerStore that I've posted before:
index.php
No one at WA has complained that I'm aware of.
markymark44
I didn't realize that powerstore was able to be changed that much...was that done with components of Powerstore or was it an applied template?
Office Guy-172461
Here's the original post:
showpost.php?p=35338&postcount=2
markymark44
How can I make remove the WebAssist Line globally?
How can I remove the line across the entire site globally without opening each and every page?
Office Guy-172461
Make the change on the template in the Template folder. When you save it, it will ask you if you want to update all pages. Click OK.
Jimmy Wu
Removing the "Copyright 2009 © PHP Scripts powered by WebAssist." line you originally asked about is fine.
