renaming files
Thread began 12/31/2009 1:49 pm by deafboyz_audio386924 | Last modified 1/05/2010 2:45 pm by Eric Mittman | 1133 views | 5 replies |
renaming files
Hope everyones holiday was good... I am triyng to rename all my uploaded files to an incrementing number. the thumbs i want a t_ before the same number.
This number must be like an ID and never be reused even if the image is deleted.
I saw some other threads similar to this but could not figure out how to implement this... all help is appreciated, thanks
Whenu you are configuring the 'if file exists' portion if you choose to rename the file you can swap out what is specified as the increment for your own value:
[NewFileName]_[Increment]
So if you had your new value that you wanted to use in a variable you could put that in here in place of the increment. You could also just append another value after this that will help you to keep the filename unique. For example if you specified the id of a record you are working with after the increment you would append that value to the file name as well. It might look like this:
[NewFileName]_[Increment]<?php echo $_SESSION['your variable'?>
ok i get what your saying and sorry for not being more clear but you know coding... :)
I dont want to rename the 'if file exists' part of DFP2.... I want the uploaded file to be renamed to a incrementing number as it is uploaded, before it is added to the DB, before it is made into a thumb and what not....
If that happens I will NEVER have a duplicate file.... the thumbs will be
t_[Incrementing#]  the original will be the SAME [Incrementing#] without the t_
If I can get the filename unique before the DB that saves me one extra step....
I experimented with the [FileName] spot and changed it to [Increment] but that doesnt work....
How do I Rename the file on upload to a 'unique incrementing id' and then add a 't_' in front of it to designate a thumb.... all before the DB is even touched?
The concept for updating the file name is the same, but you will need to come up with the logic to generate the unique id values to use. You could use some random values that you store in a variable for this in php but how do you ensure that the value has not been used before? This is not an easy thing to deal with and will require some custom coding with logic to create a truly unique id to use.
I think having a table in your db with an auto incrementing column would be the best way to start with this.
Yea I have an auto increment column... I was just thinkin if I can get the filename unique that might save me some steps in the future... If it will be too much hassle I will just take the extra step then. Thanks
This is definitely one of the trickier objectives that I have encountered in a php app. You could do some sort of hybrid solution where you have a db table with an auto increment and add to this table before uploading the file, then just use the last inserted id stored in a session variable to append to the file name. Even this would be a little complicated but I think it is an easier approach than coming up with your own method of creating auto incrementing unique ids for the filenames.
