Power Gallery, GODADDY & subdomains
Thread began 12/20/2009 10:53 pm by stevej_a2343714 | Last modified 12/21/2009 11:58 am by Office Guy-172461 | 1295 views | 3 replies |
stevej_a2343714
So I'm using godaddy as my host. I am trying to use a subdomain for my power gallery. I uploaded everything and can load my gallery page if I navigate to the absolute path: bw.php
However, if you navigate to: bw.php you can see that the page loads but the gallery does not. All I get are broken images. I tried to get help from godaddy as I believe it has something to do with the way they mask their subdomain, but they insist that the issue is in my php code.... which came from WA. Please take a look and tell me how to fix this. I have loaded, deleted and reloaded this site several different ways with the same results. The cssmenu writer files do not display properly either unless you use the absolute path.
I should also add that I uploaded the same files to another test domain that I own (without the subdomain) and everything worked great. I have a feeling I need to tell power gallery that I'm in a subdomain but am not sure WHERE to tell it this....
thanks
Steve
Office Guy-172461
Have you seen this thread?
showthread.php?t=7850
stevej_a2343714
I saw that but it did not reference using a "subdomain" so I wasn't sure it was appropriate for my issue.
I'll try this suggestion
thanks
Office Guy-172461
There seems to be an above average number of problems using dynamic sites with GoDaddy hosting in many support forums. You might save yourself a lot of grief down the road by using a host with more a conventional setup.
Just my opinion. :)
