Image Update ?
Thread began 12/17/2009 1:04 pm by Remco209061 | Last modified 12/18/2009 10:52 am by Jason Byrnes | 1595 views | 3 replies |
Remco209061
Image Update ?
Hello,
when i put a'n image in The HTML editor (local, no upload) the image is placed perfect but when i want to update the file te image is (and the script) is gone! WHY!
before the image tag is a strange sign (*).
Grts Remco
In the update I see two "" it seems to be the place holderfor something the script is <img align="quote;/Zonnew/images/034.jpg&quote;"> it seems that the script is dirty. strange because the input is right!
On the update page, you likely have some formatting on the initial value for the HTML editor.
On the update page, select the HTML editor place holder, in the property inspector, click the edit button. For the initial value, click the lightning bolt and reselect the corresponding recordset column.
Remco209061
Yes I know, and the normal input is updated and when I place an image the first time its right. But when i update again the image is gone in the code the " " is changed in a (&quote;) Why?
What are the right encoding settings?
like I said, you just need to rebind the initial value to remove the encoding. right now, the initial value, is likely:
<?php echo(str_replace('"''&quot;'$row_recordset['column']); ?>
the str_replace function is replacing double quotes with &quot;.
If you rebind the initial value, you will remove the str_replace function.
