Update and delete functions not working..
Thread began 12/15/2009 2:44 pm by doddandrew302012 | Last modified 12/21/2009 4:02 pm by doddandrew302012 | 935 views | 4 replies |
Andrew Dodd - ADDIGITAL
Hi all,
Have set up an admin system for a client, and, whilst everything appears to work, the update record (the data is the same) and delete record don't (the record still exists), when you look at the results afterwards, even refreshing the browser.
The pages appear to work but don't write any changes to the attached database. The url is login.php
Username is nam_ploy
Password is f00dp1ac3
You should then be able to access the relevant pages and try them for yourself.
Has anybody else experienced this? Or have any hints as to what might be going wrong?
Don't really want to post access details on here but am getting desperate and the client is getting twitchy.
TIA
Andrew
Your update and delete are probably not working for similar reasons, I'm not fully sure why though just based on the testing that I did.
Please give this a try, on your update page find the line that starts with this:
$WA_Sql
Just after this line in the code add this:
die($WA_Sql);
This will print out the sql for the update. If you get the sql for the update to print to your screen then we need to do some checking of this sql to see why it is not updating your db. If you do not see the sql then that indicates that the update is not being triggered properly.
Please perform this test and let us know the result.
SQL code
Hi Eric..
Here's the code for the DELETE function:
DELETE FROM `mailing_list` WHERE `femail_address`='terry%40addigital.co.uk'
and for the UPDATE:
UPDATE `mailing_list` SET `fsalutation` = 'Mr', `ffirstname` = 'Terry', `fsurname` = 'Savage', `femail_address` = 'terry@addigital.co.uk', `fstreet_address` = '36 Red Lane', `fdistrict` = 'Meltham', `ftown` = 'Holmfirth', `fpostcode` = 'HD9 5LJ', `fmessage` = '', `fopt_out` = '', `fnews` = '' WHERE `femail_address`='terry%40addigital.co.uk'
I'm frustrated beyond belief - it's just weird!!
Andrew
Based on these results it seems that the delete and update are being filtered by the email address and that this address has the @ encoded as %40. Where are you setting this value originally? I think if you had this value referenced with the regular @ it would work for you. One way you can do this in php is to use the raw url decode function, it looks like this:
rawurldecode(<you user email value>)
This should transform the %40 into the @ for you.
Solved
Thank you so much Eric.. That appears to have solved the problem..
Have a great Christmas and New Year!
Andrew
