Shipping Rules - sharing of successful formulas for non-coders!
Thread began 12/14/2009 6:27 pm by pete268226 | Last modified 12/14/2009 10:45 pm by pete268226 | 944 views | 2 replies |
pete268226
Hey, we're all asking about different shipping scenarios than those that are included automatically with PowerStore2. I'm going to start this post (and maybe ask for it to be a sticky one) so that we can start sharing those configurations with eCart that work. I'm intending this to be for non-coders, so I'll write as clearly as possible, each step. Allow me to start by adding my own small victory.
If you have one to offer, then please do so - a beginner out there will be grateful!
-Pete
Canadian Flat Rate Shipping of $7.00
Open confirm.php (or any cart-related document that contains the calculation)
Using eCart, double click on the eCart Object in the Server Behaviour Tab of DW
Click the Shipping Tab
Click the +ADD button; a new setting dialogue will open
Name your rule. I called mine "Canadian Flat Rate ($7)"
Under Triggers, click +ADD to create the first trigger:
TOTAL NUMBER OF UNIQUE ITEMS IN THE CART (set to "greater than zero")
Click +ADD to create the second trigger:
AND SESSION VARIABLE EXISTS and enter the variable you want to target
- I copied my variable name from the eCart Set Session Value item in Server
behaviors - I chose the eCartCheckoutForm_shipping_country one
Click +ADD to create the third and last trigger:
AND BASED ON SESSION VARIABLE VALUE and paste in your variable name, setting
the value comparison and value. For mine, I chose
eCartCheckoutForm_shipping_country = CA
Once your triggers are set up, go to the bottom of that dialogue box and set up the Calculation - in my instance, I chose Flat Rate and entered 7.
The important step that is needed is to upload the entire eCart directory - it contains the settings you just made. Remember to clear your browser cache and cookies often when testing.
neilo
Pete, - that's a great idea. Thanks for doing that.
pete268226
Canadian Shipping Flat Rate ($8) and Free Shipping over $100
My client also wants to offer free shipping for orders over $100. Jason tells me that shipping charges are incremental. This means that you can have 2 or more shipping charges that are all applied at the same time - that each one adds onto the total shipping amount. If you want free shipping over 100, then you need to add a trigger to all of your shipping rules so they only trigger if the total is under 100.
Following the rules I set out above, I want to edit the previous shipping rule that I made.
I will add a second trigger to the array:
Click the Shipping Tab. Select your rule and click EDIT.
Click +ADD to create the new trigger: (It will appear at the bottom - that's ok for now)
AND SUBTOTAL FOR ENTIRE CART CONTENTS <= 99.99
Use the little UP arrow to move this trigger to the second position. You may want to edit your Rule name to reflect this change.
Click OK and upload the eCart directory. Now, I have $8 flat shipping (based on my previous post) within Canada and if a customer orders more than $100 worth of product, they are charged nothing for shipping.
