Boolean option - MySQL, PHP Noob
Thread began 12/14/2009 8:04 am by walt125013 | Last modified 12/14/2009 12:45 pm by CraigR | 1501 views | 2 replies |
walt125013
I am creating a MySQL database and need to be able to have a checkbox that assigns a record as featured. I just want my user to be able to check this box to make the record appear on the homepage in a "Featured" box.
When a user logs into the adminportion of their site, they should be able to check a box in the form. How is this setup in MySQL? Specifically when using phpMyAdmin...
does this make sense?
Justin Nemeth
I would use an int column, default value of 0 to indicated unchecked. Then in your PHP code, if the box is checked set the value to 1, set to 0 for unchecked.
-justin
CraigRBeta Tester
i don't know if this is the 'right' way, but for checkboxes, i create a field of type tinyint with a length of 1 in my database, and have 0 representing unchecked and 1 representing checked.
on my page, the checkbox has a checked value of 1
