TRied everything -- cannot install css sculptor with dw cs4!
Thread began 12/12/2009 1:36 pm by scantor212684 | Last modified 12/14/2009 10:31 am by Jimmy Wu | 2121 views | 4 replies |
scantor212684
I've been trying for two hours now to install my CSS Sculptor 3 upgrade with no success!
I'v deleted the MacFileCache-###.dat file several times, rebooted several times, renamed my configuration folder, deleted and reinstalled all my extensions but still have the wacs_serial.htm error.
What else can I do? Can I get a refund? I just bought the upgrade two hours ago?
Thanks.
scantor212684
Here is a screen cap of the error I cannot get rid of...
gruant2000381341
you won't get an answer on a refund until monday, closed for weekend.
did you uninstall your prior version first?
scantor212684
I tried everything that was suggested including uninstalling the previous version. I even uninstalled all the other extensions I was using just in case there was some king of conflict.
Nothing worked.
Jimmy Wu
The line of code referenced by this error indicates that you are unable to connect to our activation server. If you have any security, virus scan or firewall software, please disable it while activating. If you are unable to do so, please let me know.
