Email and Go Daddy
Thread began 12/09/2009 12:10 pm by rmcadams351257 | Last modified 12/10/2009 12:02 pm by Eric Mittman | 2324 views | 1 replies |
rmcadams351257
Email and Go Daddy
I have not been able to get the email for my Powerstore to work with Go Daddy.
I have made the changes out lined in the known issue's section for Powerstore & the posts here. ie: leaving the mail server blank ( $WAGLOBAL_Email_Server = "" ;) ect. Nothing works so far. Yesterday I was trying to see if I could get it to send me my user password, through the "Forgot Password" page. When I entered my email address and clicked send, it gave me this error at the top of the page...
Warning: mail() [function.mail]: SMTP server response: 451 See smtplf.html. in D:\Hosting\5016247\html\WA_Universal_Email\mail_PHP.php on line 254
Well when I got that I had see what the "server response 451" was. So I went to the web address listed in the error code and got this.
Most likely you're here because your mailer displayed the pointer ``See smtplf.html.''
Where did that pointer come from?
It was generated by qmail, an Internet message transfer agent. Your mailer tried to send an e-mail message to a server running qmail. Unfortunately, qmail spotted a problem: your mailer sent a bare LF.
Why should I worry about bare LFs?
You can't get mail through to msn.com and thousands of other systems around the Internet. Your mailer is violating 822bis section 2.3, which specifically prohibits all bare LFs.
How can my mailer be fixed?
That depends on what software you're using.
Solaris 2.5 sendmail: Upgrade! Fixed in Solaris 2.5.1. You can fix the problem by putting ``,E=\r\n'' at the end of Mether, Mtcp, or Msmtp in sendmail.cf. (Note that Mether is not the same as DMether.)
sendmail V8 has a bug that will produce a bare LF in certain messages (e.g., messages with very long lines). This bug was identified in November 1996; I don't know if it has been fixed yet.
Eudora Pro 4.0 for Windows: Upgrade! The HTML LF problem was fixed in 4.0.1. The attachment LF problem was fixed in 4.1.
listproc 6.0c: Chuck Foster says you should add ``CONVERT(buf);'' before ``WRITE_TO_SOCKET'' around line 165 of sysmail.c in the Listproc source code.
fetchmail: Upgrade! Recent versions of fetchmail reportedly do the right thing. Make sure the forcecr option is on.
Galacticom WorldGroups: Reported 19970716. No information on how it can be fixed.
Claris Emailer: Reported 19980613. No information on how it can be fixed.
CipherTrust's IronMail SMTP gateway: Reported 2002.10.29 by Christopher Mahmood. No information on how it can be fixed.
What is a bare LF, anyway?
It is an ASCII linefeed (LF) character not preceded by an ASCII carriage-return (CR) character.
Every line in an Internet mail message is required to end with CR LF. The entire message ends with CR LF dot CR LF. 822bis specifically prohibits other uses of LF.
The mail clients discussed above are incorrectly ending lines with LF and, in most cases, ending the entire message with LF dot LF. That's not CR LF dot CR LF, so a server such as msn.com will sit there waiting for the rest of the message. After a while it'll give up and drop the connection. Your mail doesn't get through.
Some mail servers convert a bare LF into CR LF, and accept LF dot LF as the end of a mail message. This behavior is specifically prohibited by 821bis.
I'm not at all sure what all that means, But it does look like it might help finding out why Powerstore and go daddy have not been working together to send my stores emails.
I'm at a loss as to what to do. But I think with this info, one of you wonderful Webassist Tech support wizards can crack this nut.
O yeah thanks again Eric for your help on the last help ticket. Your the best
Ron
Thanks for the info about this. I have opened a ticket for you on this issue so we can look into this further. To update the ticket please login to WebAssist.com and visit your support history.
