Glitch with a menu in IE (6)
Can anyone think what might be causing the menu that works OK here :
index.php
To not be working here :
usedvehicles.php
It seems to be OK in Firefox and Safari, but not working in IE6.
Many thanks...
index.php
usedvehicles.php
Many thanks...
Hi Ian,
The IE6 conditional code calling for the ie6 stylesheet is pointing to the wrong place.
Try changing:
<!--[if lte IE 6]>
<link rel="stylesheet" type="text/css" media="all" href="../CSSMenuWriter/cssmw/menu_ie3.css" >
<![endif]-->
<!--[if lte IE 6]>
<link rel="stylesheet" type="text/css" media="all" href="CSSMenuWriter/cssmw/menu_ie3.css" >
<![endif]-->
Thanks Neilo - that wasn't it, but amazingly I figured it.
I tried removing bits of code, and it worked when I took out the PHP code that was controlling the array for the drop down of vehicle makes in the search.
I tries moving the call for the menu CSS to before that script, and that fixed it.
Glad you got it sorted! (Though I'm still not sure why the IE6 conditional is pointing to '../CSSMenuWriter/cssmw/menu_ie3.css' rather than 'CSSMenuWriter/cssmw/menu_ie3.css' !)
