No images just loading graphic
Thread begun 12/08/2009 8:01 pm by Jaffa | Last modified 12/08/2009 9:08 pm by Jaffa | 1476 views | 1 replies |
Jaffa
None of my image are showing if you look at this page:
gallery.php
tried changing the global.php as suggested in another thread but the code given was already there.
//make sure the $_SERVER['DOCUMENT_ROOT'] variable is set (IIS doesn't set it)
if(!isset($_SERVER['DOCUMENT_ROOT'])) {
if(isset($_SERVER['SCRIPT_FILENAME'])) {
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr($_SERVER['SCRIPT_FILENAME'], 0, 0 - strlen($_SERVER['PHP_SELF'])));
if(isset($_SERVER['PATH_TRANSLATED'])) {
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr(str_replace('\\\\', '\\', $_SERVER['PATH_TRANSLATED']), 0, 0 - strlen($_SERVER['PHP_SELF'])));
//$_SERVER['DOCUMENT_ROOT'] is now set
Please help
Jaffa
Sorry I found the error it was with another javascript on my page causing the gallery not to work - wierd
