Shipping based on total QTY of items in cart...???
Thread began 12/07/2009 7:28 pm by andrew189999 | Last modified 12/08/2009 9:43 am by Ray Borduin | 1368 views | 3 replies |
andrew189999
I'm sure this is simple but I can't seem to figure it out. All I need to do is charge $8 for the first item in the cart and $5 for each additional item. There are multiple products but they all weigh the same and follow the same shipping rule. Simply $8 for the first unit and $5 for each additional.
I tried to create a calculation called AdditionalShipping and I set it to
([QUANTITY] -1) * 5
Then I figured I'd create a shipping rule that just does $8 + AdditionalShipping. My AdditionalShipping calculation doesn't show up in the drop downs under the rules, though, like the other calc values do..??
Any information on this would be greatly appreciated. Thanks!
I'd skip creating the calculation and just set your shipping to:
Multiple of a column total, and use:
(Quantity * 5) + 3
andrew189999
yup
I knew I was making it harder than it needed to be. Thanks!
For future reference, how come that calculation I was making isn't showing up in the drop downs like the rest of the cart columns/calculations do?
I'm not sure. It really should show up. Maybe you have to hit OK after making the calculation and apply it before it shows up in the shipping rules.
