trying to run a sale
Thread began 12/07/2009 12:50 pm by barbara224891 | Last modified 12/10/2009 5:01 pm by Jason Byrnes | 884 views | 4 replies |
barbara224891
Hi, I have a site which would like to run a holiday sale. They have 30 or so items with prices that vary. During the sale, they'd like it to be 5 for $35 or 10 for $65 or 20 for $120, regardless of what items make up the 5 or 10 or 20.
I tried to make a discount equal to the cart subtotal in order to get rid of the regular prices and then a charge that had 4 tiers depending on whether total q is less than 5, between 5 and 10, etc.
I must have misspecified the discount, as the cart insists on adding in the old prices in addition to the sale prices. I've made the sale prices inactive until I can get the discount to work (some sale if things cost more, right?).
Here's the code from the cart object page which contains the discount and the 4 tiers:
function WAEC_WA_eCart1_removeregularpricesforsale() {
$totalDiscount = 0;
if (true && (($this->TotalColumn("TotalPrice") > 0))) {
$totalDiscount += (floatval($this->GetInfo("0", "TotalPrice")) * 0);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
//eCart Rule
function WAEC_WA_eCart1_tier1() {
$totalCharge = 0;
if (false && (($this->TotalColumn("TotalQuantity") < 5))) {
$totalCharge += (($this->TotalColumn("TotalQuantity") * 7.5) + 0);//Result
return WA_eCart_FormatNumber($totalCharge, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
//eCart Rule
function WAEC_WA_eCart1_tier2() {
$totalCharge = 0;
if (false && (($this->TotalColumn("TotalQuantity") >= 5) && (sizeof($this->Items) < 10))) {
$totalCharge += ($this->TotalColumn("TotalQuantity") * 7);//Result
//eCart Rule
//eCart Rule
function WAEC_WA_eCart1_tier3() {
$totalCharge = 0;
if (false && (($this->TotalColumn("TotalQuantity") >= 10) && ($this->TotalColumn("TotalQuantity") < 20))) {
$totalCharge += (($this->TotalColumn("TotalQuantity") * 6.5) + 0);//Result
I'm also experiencing something concerning in that after every time I try to edit the cart object, I get a message that the cart object file has been edited outside of dreamweaver and I'm asked if I want to reload. But I haven't edited outside of DW, so where's that coming from? I wonder if there could be an issue about what version of ecart I used when I set the site up and what one I'm using now. I seem to be running 4.5.0 now. Not sure what I had when I set the site up, but it's been running a long time.
Any help? I'm attaching the cart object page. Oops, can't do that, as php files can't be uploaded. Have pasted the relevant code above.
you wont be able to override the Price using a Discount or charge rule, you will need to do that by crating a calculation on the calculation tab.
On the calculation tab create a new calculation named "holidayBasePrice" as:
[Price] = 35
This will set the price for any item added to the cart to $35
The create two charges to increase the price based on the quantity For 10 - 20 and another for 20 or more like you have below.
barbara224891
I'm having trouble following your directions. I edited the calculations as follows:
//start node
function ResetCalculations($itmObj) {
$itmObj->TotalWeight = $itmObj->Weight * $itmObj->Quantity;//w
$itmObj->TotalPrice = 7.5* $itmObj->Quantity;//c
$itmObj->FullDetails = $itmObj->Quantity . ' ' . $itmObj->Name . ' (' . $itmObj->ID . ')';//t
$itmObj->TotalQuantity = $itmObj->Quantity;//n
$itmObj->holidayPrice = 7.5;//c
return $itmObj;
//end node
This sets the price for every item to the unit price if there is no discount, $7.50. This part is showing up properly in my cart now.
Next, I redid the tiers to calculate a discount based on how many total items are in the cart. These have the effect of lowering the cart title by the discount in unit price times the total quantity of all items in the cart. This is how they look:
//Discounts
$this->Discounts[] = new WA_eCart_Rule(urldecode("tier1"), true, "WAEC_WA_eCart1_tier1");
$this->Discounts[] = new WA_eCart_Rule(urldecode("tier2"), true, "WAEC_WA_eCart1_tier2");
$this->Discounts[] = new WA_eCart_Rule(urldecode("tier3"), true, "WAEC_WA_eCart1_tier3");
//Charges
//Tax
//Shipping
$this->Shipping[] = new WA_eCart_Rule(urldecode("base"), false, "WAEC_WA_eCart1_base");
$this->Shipping[] = new WA_eCart_Rule(urldecode("increment"), false, "WAEC_WA_eCart1_increment");
//end node
//start node
//eCart Rule
$totalDiscount = 0;
if (true && ((sizeof($this->Items) >= 5) && (sizeof($this->Items) < 10))) {
$totalDiscount += ($this->TotalColumn("TotalQuantity") * .5);//Result
//eCart Rule
//eCart Rule
$totalDiscount = 0;
if (true && ((sizeof($this->Items) >= 10) && (sizeof($this->Items) != 20))) {
$totalDiscount += ($this->TotalColumn("TotalQuantity") * 1.0);//Result
//eCart Rule
//eCart Rule
$totalDiscount = 0;
if (true && ((sizeof($this->Items) > 20))) {
$totalDiscount += ($this->TotalColumn("TotalQuantity") * 1.5);//Result
//eCart Rule
Finally, I add a line in the cart to display the discount, using this binding: <?php echo $WA_eCart1->GetDiscounts(); ?>.
However, the discount does not show up and the total is not affected. I have the tier rules selected as active, but obviously, they are not.
Help, please?
barbara224891
OK, I just managed to figure out a work-around. For some reason the discount wasn't showing up in my total, but I remembered that on my initial iteration when I'd been working with charges, they were showing up, so I redid the discount as negative charges and that shows up fine.
So, never mind.
Ok, glad to hear it is working.
