Ecart on web site not working. Need help
Thread began 4/29/2009 4:53 am by Joe377587 | Last modified 4/29/2009 7:57 am by Ray Borduin | 1311 views | 1 replies |
Joe377587
OK I located the licenses for the software used to make the site. I would like to pay someone for some help. I just need to get the checkout process working. Everytime we click on add product to cart from the pricing.php page, the next page that opens "cart.php", shows text stating the cart is empty. I don't know what is not happening or what is not happening...
I copied all the files over from old server and got the SQL file working fine. I don't have a clue about using webassit extensions.
Please contact me at davteks@hotmail.com with contact info and hourly rate or If you just what to help a guy out. Thanks.
Joe
It might just be the form action on the add to cart page, or a problem with the add to cart server behavior. Do you have Dreamweaver? Do you want to try to do it yourself? That might be your only problem and it could be very easy to fix.
Check the form action, check the add to cart server behavior, and make sure the cart objects match up. It should be very easy.
