Connection Error with PayPal
Thread began 12/06/2009 9:39 am by mrobben375515 | Last modified 12/07/2009 8:34 am by siteontime | 1464 views | 4 replies |
mrobben375515
We are signed up with PayPal Website Payments Pro. We think we have the WA_Globals.php setup correctly. I pasted the setting below. When I click on the "Checkout" button, I get checkout_failure.php page. How can I diagnose where the problem is?
/* Payment Settings
* Use this key to determine the appropriate value for the $WAGLOBAL_Gateway setting:
* PayPal = 1
* Authorize.net = 2
$WAGLOBAL_Gateway = 1; //Enter the appropriate value based on the above key. PayPal is specified by default.
$WAGLOBAL_Test_Mode = false; //Set to true if you are testing your shopping cart and do not want to send information to your payment gateway.
//Only complete the payment gateway options for the gateway you have selected to use in the $WAGLOBAL_Gateway setting.
//PayPal Settings
$WAGLOBAL_Paypal_Sandbox = "false"; //Set to true if you wish to use the PayPal Sandbox for testing transactions.
$WAGLOBAL_Paypal_User = "mrobben@1to1marketing-inc.com";
$WAGLOBAL_Paypal_Password = "XXXXXXXXX"; ***(I blocked out the PW)
$WAGLOBAL_Paypal_Signature = "XXXXXX2GW"; ***(I blocked out the Sig)
//Authorize.net Settings
$WAGLOBAL_Authnet_Sandbox = "false"; //Set to true if you wish to use the Authorize.net Sandbox for testing transactions.
$WAGLOBAL_Authnet_login = "";
$WAGLOBAL_Authnet_tran_key = "";
siteontimeBeta Tester
The paypal userid doesn't look correct to me. For website payments pro userid is not normally an email address.
If you just put that in there for the post, then the next thing to check is error message being returned from Paypal. On the checkout failure page in the bindings panel you want to add the ecart bindings for local checkout response .
The bind the full response to the page. This will display the error code from Paypal.
Hope that helps.
mrobben375515
I was wrong about the PayPal version I have. I called PayPayl and I do not have Website Pro. I have Website Payments Standard. Will this work or do I need Website Pro?
mrobben375515
It works after I signed up for the right PayPal account
Glad you got it working.
