Highlighting "Top level of current page" revisited
Thread began 12/01/2009 5:11 am by cpfusion | Last modified 12/03/2009 12:26 pm by Jason Byrnes | 1212 views | 3 replies |
cpfusion
Hi there all,
I am currently using CSS Menu Writer 2.0.3 and have used it successfully on a few sites with only one problem "Highlighting Top level of current page", which was solved with the help of Jason Byrnes (thanks Jason).
However, this problem has arisen again, albeit in a slightly different manner...
I have a site which is unfortunately not highlighting the "Top level of current page" when the sub menu pages are linked to via a hyperlink with added parameters e.g. archived_news.php?yr=2009&m1=07&m2=09
If I remove the parameters at the end of the URL, the menu highlights correctly.
Is there something I can do to make this work as it should?
Thanks in advance,
Craig
in the menu.js file, find the following code:
//all url vars in the link must be in the page url
for (var n=0; n<tVarArr.length; n++) {
if (hrefURLVars.indexOf("&" + tVarArr[n] + "&") < 0) {
return false;
and change it to:
if(testPage.indexOf("?")>= 0) {
return false;
cpfusion
Jason, once again many thanks for your help in sorting this problem out for me. Much appreciated.
I realise that I will have to make this amend again if I have to republish the menu, will this amendment to the menu.js file be written in to the next update of CSS Menu Writer?
Craig
Yes, it has been logged as a bug, so it should be included in the next update.
