JavaScript with Dynamic Dropdowns
I'm using your DD feature but I cannot figure out how to get JavaScipt to display results. My site is packagespage.php and I'm looking to get a fee result.
when I run your page, the select lists are not active. I cannot use them. In the Fire Fox Error console, it is showing an erro that edit is not defied. it seams to be complaining about the following line:
<CM4ALL:TEXT oncontextmenu=_edit.contextMenu(); onpaste=_edit.paste();
id=txt10701 onkeydown=_edit.keyTest(); onblur=_edit.blur();
onkeyup=_edit.keyTest(); contentEditable=true ondrop=_edit.drop();
style="WIDTH: 100%; HEIGHT: 100%; BACKGROUND-COLOR: #666666"
onfocus=_edit.focus(); useLink="true" useItalic="true" useBold="true"
type="PARAGRAPH" recommendedTextLength="-1" maxTextLength="-1" imageCount="1"
previousTabStop="txt24301" nextTabStop="txt10001"
sSectionID="10701">
This seams to be conflicting with dynamic dropdoowns
