Known issue (and solution) for Canadian postal code validation
Thread begun 11/30/2009 3:02 pm by Anna Robinson | Last modified 12/07/2009 4:39 pm by toms016390756 | 4647 views | 1 replies |
Anna Robinson
In CSS Form Builder Version 1, Canadian zip/postal codes do not validate correctly.
A simple fix is posted in the Download Center on the CSS Form Builder download page (in the Known Issues section), but I will also post the fix below.
Follow these steps for applying this fix manually.
Note: Variable names may differ in your form.
1. Open the page with the form that uses the Canadian formatted postal code validation.
2. In Code view, locate the WAValidateZC procedure call:
WAValidateZC((isset($_POST["fieldset_group_field"])?$_POST["fieldset_group_field"]:"") . "",false,false,false,true,false,1);
3. Change where it says 'false,true' (highlighted in blue) to 'true,false'.
WAValidateZC((isset($_POST["fieldset_group_field"])?$_POST["fieldset_group_field"]:"") . "",false,false,true,false,false,1);
4. Save the file.
toms016390756
Thanks for clearing this up for me//
--- My baby:
