Renaimg uploaded files with Digital File Pro
Thread began 11/30/2009 6:23 am by pc316991 | Last modified 11/30/2009 4:36 pm by Dani Chankhour | 702 views | 1 replies |
pc316991
Can you tell the syntax required for renaming files uploaded using Digital File Pro.
I am uploading either doc, docx, rtf, or pdf files and I want to rename them with an id # extracted from a record set, followed by the fielname and extension, with any spaces replaced with an _ if possible.
So a filename might look like this
2345_my_cv.pdf
Dani Chankhour
Look for the DFP function: WA_DFP_UploadFiles on your page and for the forth parameters, you will need to change it to look something like this:
"".$row_Recordset1['ID'] ."_[ExistingFileName]"
You can see that we are concatenating the ID to the file name. But to replace empty space with underscores, we will need to add this statement:
$_FILES['fileField']['name'] = str_replace(" ", "_", $_FILES['fileField']['name']);
before the DFP Upload server behavior.
