Authorize.net will not approve payments
Thread began 11/27/2009 9:46 am by flhomesites394744 | Last modified 11/27/2009 1:10 pm by flhomesites394744 | 1024 views | 7 replies |
flhomesites394744
I finally got everything working accept Authorize.net will not approve any payments even though all fraud settings are disabled.
How can I figure out what is wrong and even if my website is communicating with authorize.net?
thanks!!!
Office Guy-172461
See if this helps:
How to add Payment Gateway Response to your Transaction Failed pages
83/
flhomesites394744
I am new to all this.
Do I need to setup a database on my server for the shopping cart to work? If so, what files if any do I have to load in the database?
Thanks!!!
Office Guy-172461
Technically no. But I would go the database route even with a few items because it offers so much more flexibility. Once you setup one database, it's simple to do it again.
The Database Starter Kit is highly recommended (now free):
database-for-php/
I would go through all of the resources included with eCart. Many people forget to look at all of the resources that are included with the extension in your download area.
flhomesites394744
You are really helping alot, THANK YOU!!
Here is the response on my page that I received:
3 -Response Code
1 -Response Sub Code
270 -Response Reason Code
(TESTMODE) Line item 1 is invalid. -Response Reason text
Office Guy-172461
Maybe someone that uses Authorize.net can help you with the codes, but I would look to make sure that the variables you are sending match the type they want. It's looks like your are sending a text variable when they want something else.
flhomesites394744
Would it help if I send over one of my pages and which one?
flhomesites394744
I found the issue.
I had the ID set at 0. Once I put it to 1 it works.
