adding same prod with different size to ecart
Thread began 11/26/2009 6:08 pm by watercolor346374 | Last modified 11/30/2009 6:28 pm by Eric Mittman | 1445 views | 3 replies |
watercolor346374
I am still having problems with the sizes.
On my server it works, if a prod does not have a size the size form does not show up, if it has a size it shows up. On the live site: it does not work.
link: signature.php This collection has rings with sizes and necklaces without.
<input type="hidden" name="megan_1_ID_Add" value="<?php echo $row_rsDetail_popheart['prodid']; ?>" />
<input type="text" name="megan_1_Quantity_Add" value="1" size="2" >
<?php if ($totalRows_rsSize > 0) { // Show if recordset not empty ?>
<label style=" margin-left:5px" >
<select name="megan_1_size_Add">
<option value="" selected>Select Size</option>
do {
<option value="<?php echo $row_rsSize['size']?>"><?php echo $row_rsSize['size']?></option>
} while ($row_rsSize = mysql_fetch_assoc($rsSize));
$rows = mysql_num_rows($rsSize);
if($rows > 0) {
mysql_data_seek($rsSize, 0);
$row_rsSize = mysql_fetch_assoc($rsSize);
?></select></label>
<br />
<br />
<br />
<input type="image" src="images/add_to_bag_final_300dpi2.jpg" border="0" value="Add to Cart" name="megan_1_ATC">
</form>
I was also wondering how I can change the style of the size menu. I just want a plain dropdown with arrows, no blue and shine.
Thank you
From the code that you have posted here is looks like the select list should be hidden unless there are rows in the recordset. Looking at the source code on your pages I'm not sure that you have the same code. On the live site it looks like the select lists have different names. One other thing that I notice is that if the code to hide the rs was not working properly the select lists should have a default value of Select Size. Since even the items with sizes to select do not have this option it tells me that the code on your live pages differs from the code you have on your testing server. You should check and compare them and try uploading the copy of pages that are working on your testing server.
watercolor346374
code on pages
I took the code out of my live pages cause I kept getting messages:
Here is the code I was using:
do {
if($rows > 0) {
?></select></label>
<br />
<br />
<br />
</form>
Something is amiss with it.
Thank you
I'm not sure how you would see the select list on the live pages if this code is working properly. If you can please post back and include a copy of your add to cart page in a zip archive. I can take a look at it to see if there may be something else going on.
