Updating eCart 4.5.1 to 4.5.2 causes Javascript error
Thread began 11/25/2009 8:10 am by Suggs | Last modified 11/25/2009 11:26 am by Jason Byrnes | 1383 views | 5 replies |
Suggs
Hi folks,
Ive just updated from eCart 4.5.1 to 4.5.2 and each time I go to insert a new Add to Cart Button I am getting the following error:
While executing onClick in WA eCart AddToCart.htm, a JavaScript error occurred
Ive cleared out my wincache file and it is still happening.
Cheers
Paul
Office Guy-172461
Hard to tell without knowing what the error is.
Solving problems with Dreamweaver
146/
Suggs
The error is listed in the post.
Its While executing onClick in WA eCart AddToCart.htm, a JavaScript error occurred
This happens when I add the add to cart button and attempt to bind it..
No problems whatsoever with 4.5.1
Cheers
Office Guy-172461
Nothing after the name of the error? No line numbers?
Suggs
no, none...just the general message as stated.
Ive attached a copy of it for you to see.
As soon as you click on the Look up item ID from recordset radio button it appears.
Like I say, it didnt happen in 4.5.1 and ive built loads of sites with eCart.
Thanks for your help by the way.
Paul
Does the recordset on the page have an Order By Clause?
If so, try removing the order by clause from the recordset before applying the add to cart dfrom recordset behavior. you can add it back in afterwords.
