Rating System for Dreamweaver?
Thread began 11/24/2009 1:46 pm by ijk76319396 | Last modified 2/16/2011 1:30 pm by biz295654 | 10214 views | 17 replies |
ijk76319396
Are there any systems that can help build a rating system, for example a user is looking at a particular page and they have the ability to rate it. I want to record that rating and have some way of displaying the average rating that all users have submitted for the specific page...Where do I begin with this one?
clickhappy392103
I found a thread on this subject in another site that may help you with this.
view_topic.php?cat=1&otid=14165&forum_name=General&title=Rating%20Sytem%20Help
I have not really looked into it just yet, just bookmarked it for later when/and if I get some time.
hmm, I think the above is a bad link...
here's the direct link
css-star-rating-part-deux/
Here is a simple star rating javascript we use for our support incident ratings:
<script>
freeze = 0;
hasRated = false;
function point_it(event,freezeit){
pos_x = event.offsetX?(event.offsetX):event.pageX-document.getElementById("rating_image").offsetLeft;
pos_x = Math.round(pos_x/14)*14;
document.getElementById('rating_gradient').style.width = pos_x+"px";
if (freezeit) {
hasRated = true;
freeze = pos_x;
document.getElementById('hiddenRating').value = pos_x/28;
document.getElementById('RatingText').innerHTML = 'Current rating: <str' +'ong>'+(pos_x / 28)+'<\/strong>\/ 5';
function returntofreeze(){
document.getElementById('rating_gradient').style.width = freeze+"px";
</script>
How would you rate this?
<br />
<div id="rating_image" style="position:absolute"><img src="http://www.webassist.com/images/star_cutout.gif" width="140" height="28" alt="rating" onmousemove="point_it(event)" onclick="point_it(event,true)" onmouseout="returntofreeze()"/></div>
<div id="rating_gradient" style="width:0px;overflow:hidden;display:block;"><img src="http://www.webassist.com/images/star_gradient.jpg" width="140" height="28" /></div>
<input name="hiddenRating" type="hidden" id="hiddenRating" value="0" />
<div id="RatingText">Current rating: <strong>0</strong>/5</div>
You can probably just cut and paste it onto a form on your page and use the hidden form element to insert into a database or whatever else.
ijk76319396
I've been trying to work in the star rating system you provided but it doesn't seem to work. I am putting the top half in the head section and the bottom half where I want it to appear but I only get a flat image that doesn't do anything. Here is the example
300.php
This is my fault for not putting it in a code window... the forum added random spaces in the javascript.
replace: .style.w idth
with: .style.width
and it should start working. I also updated my post to use a code window, so copy and paste again and it should fix it as well.
ijk76319396
I used the sample from the link that was posted and it is working good but I need to have it do two things. One I want the stars to stay lit after I roll off of them and two how can i get the value into a database once I click submit?
300.php
I have figured out the stay lit part, still need to know how to get the value into a database...
The star rating is automatically inserted into a hidden form element named "hiddenRating". You can use that form element to update the database just like you would any other form element, by using an insert or update server behavior and specifying the hidden form element for the value.
You would put it in a form and either associate a button with it or add a formname.submit() javascript call to the onclick so that the form is automatically submitted and can be inserted.
ijk76319396
Could you elaborate on the option of having what star I click be assigned to a hidden field with the form I am using at 300.php after it is recorded into the hidden field then the submit button will enter it into the database. I just need to know how to get the value of stars they click into the hidden field. Thanks.
Well you aren't even using the star rating script I suggested. You seem to have a some other star rating. You will need to add some script to update the hidden form. You would add a hidden form element to the form with the star rating system. Give it a value of 0 and an id of "hiddenFieldID".
Then use javascript to update it... something like:
<li><a href="javascript:document.getElementById('hiddenFieldID').value=1;" title="1 star out of 5" class="one-star">1</a></li>
<li><a href="javascript:document.getElementById('hiddenFieldID').value=2;" title="2 stars out of 5" class="two-stars">2</a></li>
<li><a href="javascript:document.getElementById('hiddenFieldID').value=3;" title="3 stars out of 5" class="three-stars">3</a></li>
<li><a href="javascript:document.getElementById('hiddenFieldID').value=4;" title="4 stars out of 5" class="four-stars">4</a></li>
<li><a href="javascript:document.getElementById('hiddenFieldID').value=5;" title="5 stars out of 5" class="five-stars">5</a></li>
ijk76319396
I wrote the code just like in the example but it takes me to a different URL when I click on the stars and it shows the value. Please see the example, just click on any of the stars and you will see what I mean. The code looks like
<ul class="star-rating">
<li class="current-rating" style="width:50%;">Currently 2.5/5 Stars.</li>
</ul>
<input name="hiddenFieldID" type="hidden" id="hiddenFieldID" value="0" />
