W3C Compliance and SEO with Power Gallery?
Thread began 11/24/2009 8:01 am by tjewrk99472 | Last modified 11/24/2009 12:17 pm by Justin Nemeth | 1103 views | 1 replies |
tjewrk99472
2 things that are important to me.
Valid code and optimizing for Search Engines.
Do you have an example that validates and also where the alt tags are not empty for the images?
Otherwise looks good.
Justin Nemeth
The galleries are designed to be compliant XHTML 1.0 Strict code. If you need to update anything to make the gallery more compliant, you can just edit the index.php file for the gallery you want to use. So if you wanted to add more description alt tags for instance.
-justin
