removing security question
Thread began 11/23/2009 2:41 pm by msjj000 | Last modified 11/25/2009 2:49 pm by Jason Byrnes | 854 views | 3 replies |
msjj000Beta Tester
Hi WA,
I've been attempting to remove the security question on one site for the contact us form without success. Can you please point me on the right direction to capture everything please?
Thanks, Mark.
from the powerStore contact us page, delete line 290:
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
line 251 - 269:
<div class="text"><?php require_once("WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php"); ?></div>
            </p>
            <p>
                <label for="Security_question">Security Question:</label>
                 <span id="sprytextfield4">
                            <input name="Security_question" type="text" class="inputValue" id="Security_question" onblur="if (document.getElementById('securityServerError')) document.getElementById('securityServerError').style.display='none'" maxlength="40" />
                            <span class="textfieldRequiredMsg">A value is required.</span>
              </span>
if (ValidatedField("contact","contact"))  {
                                if ((
strpos((",".ValidatedField("contact","contact").","), "," "5" ",") !== false || "5" == ""))  {
                                    if (!(
false))  {
                                    <span id="securityServerError" class="textfieldServerError">Your answer was not correct.</span>
                                    <?php //WAFV_Conditional contact.php contact(4:)
            </p>
and line 26:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?$_SESSION["random_answer"]:"") . "",true,5);
msjj000Beta Tester
Hi Jason,
Thanks for your help - that worked a treat.
Regards, Mark.
you're welcome.
