QueryString Binding Issue with DataAssist Sort
Thread began 11/23/2009 7:53 am by info307537 | Last modified 5/18/2010 12:54 pm by Jimmy Wu | 4819 views | 20 replies |
info307537
I am working through this tutorial: link_sorting.swf , but I am having an issue when I get to the stage where you need to create a QueryString binding...
I type "sort", then click "ok" and I get the following error message: "There are no QueryString bindings defined for this page".
What am I doing wrong as I am following your tutorial???
Jimmy Wu
When entering in the QueryString Binding name, try hitting tab and/or enter a few times before finishing the wizard. The name sometimes does not get saved correctly unless you do this. This issue should be fixed in the next release of the product.
info307537
RE: QueryString Binding Issue with DataAssist Sort
Thanks for your reply. That has solved the problem. Sounds like a software bug that needs fixing to me though, as I can imagine lots of other people having the same issue.
Jimmy Wu
That is correct, there is already a bug logged and it will be fixed in the next dot release of the product.
twitchr377598
I'm getting the same error. I tried pressing tab and enter a bunch, but still get the error.
After that error I get:
The following JavaScript error(s) occurred:
At line 746 of file "[pathto:]WATrigger.js":
ReferenceError: WA_getDocumentDOM is not defined
I uninstalled and reinstalled the extension. Still get the same result.
Thanks in advance.
Twitch
Jimmy Wu
What version of the extension are you running, what version of Dreamweaver and which operating system are you running on? If you're using Mac, please specify Intel Mac or Power PC.
twitchr377598
Sorry about not supplying that info in the original post. Meant to do it and it completely slipped my mind when I was typing.
Extension version 2.0.6
Intel Mac OS 10.5.8
Dreamweaver CS3 Version 9 Build 3481
Jimmy Wu
Thanks, I'll take a look at this issue and get back to you with a fix.
jo4koalas392067
Not sure if this is any help, but I got the same error and ignored it. I then went on to set the sort server behaviours and it worked perfectly on my local test server.
Jimmy Wu
Thanks for the input, any workarounds are always appreciated.
