Error Generating Menu Again
Thread began 11/23/2009 7:05 am by clive.henderson222953 | Last modified 12/02/2009 11:08 am by Jimmy Wu | 1530 views | 3 replies |
I'm getting the same errror again as ticket #109605've deleted the wincache file but this has not helped
Jimmy got me past the last problem by amending the shared Js file but it has reappeared again (I have not reinstalled the extension or changed the shared js file)
Generating static menus always works fine.
It's just the dynameic menus that fail when trying to create the menu.php file in CSSMenuwrite folder
Appreciate any help please
Regards
Clive
Jimmy Wu
Is this only when you're editing the menu again or is it when you're applying it initially?
Error Generating Menu Workround
I've been experimenting with various options this week and this is what I've found.
1. Whenever I try to create or amenda dynamic menu without deleting the wincache file first it always fails.
If I delete the wincache file and manage to amend or create a new dynmic menu successfully, the extension will fail the next time I try to use it without deleting the wincache file first.
So I've got a way forward.
Thanks again Jimmy for the assitance before.
Kind Regards
Clive
Jimmy Wu
Glad you were able to find a workaround. If you run into any additional issues, feel free to open a new thread.
