Problem with image upload
Thread began 11/23/2009 8:40 am by webladesign285835 | Last modified 11/23/2009 8:03 pm by Jason Byrnes | 1700 views | 4 replies |
webladesign285835
Friends, I have a problem with Digital File Pro and Data Assist. I created The administrator of the site and contains several sections. Most of them work correctly when the images upload. But in two sections, having performed the same procedure was an error sending them here in various attachments. I need help. Thank you. I attach 3 files: Error Page, Code and Permissions in this files on server.
error_in_page.txt
CraigRBeta Tester
this may be unrelated, but i had a similar problem recently.
check the upload folder path on your insert and update pages and ensure that the path doesn't start with a forward slash
eg
'UploadFolder' => "images/", works ok
'UploadFolder' => "/images/" gives errors
i found both worked when uploaded to a hosting (linux) server, but on my testing server (windows) i got a problem
The error massage is saying that the public_html/images/lg folder does have the proper permissions.
You may be able to modify the permissions using Dreamweaver, if not you will need to use an FTP program, or your host may have a website management utility that allows you to change permisions on folders.
In Dreamweaver, open the File Panel. In the view Select List, select Remote View.
Right Click the public_html/images/lg folder and select Set permissions.
The Owner must have Read, Write and Execute permissions.
For the User/group and Everyone, Read, Write should be sufficient.
webladesign285835
The problem persist
The problem persist! im follow step by step your instructions but dont work!
can you verify that the permissions on the images/cenagala/lg and images/cenagala/tn folders allow rear and write for all users?
if changing the permissions does not work in Dreamweaver, you will have to find another way of setting the proper permissions for those folders, either using an ftp program or you hosts control panel to manage you site.
