How to add validation to a new form field?
Hi
I'm looking to add a new mandatory field in my form for a Post Code, how do I add validation to this so that the form won't send unless the Post Code has been added?
Hi
Hi Keith
Insert > Webassist > CSSFormBuilder > Client Validation
Select the Form > 'Next'
Type lines to precede an succede the error message dialogue > 'Next'
Select the Form element to validate (i.e. PostCode) and Validation Type (i.e. Zip Code) - Click the + button
Select some or all of allowed postcode types, and additional configuration options - > OK
(Add more validation types if required)
Click 'Finish'
Hi
I'm not actually using the product 'CSS Form Builder', I'm using the 'Contact Form Solution Pack'
How would I do that in that product?
You cannot add validation to the Contact Form Solution Pack unless you use the CSS Form builder Extension.
