Adding file name to database
Thread began 11/22/2009 11:20 pm by arista341524 | Last modified 11/23/2009 10:59 am by Jason Byrnes | 1306 views | 1 replies |
arista341524
Hello - Thanks in advance for any help you can offer.
I'm so close to being done with this website, but I can't figure out how to finish this final part. I've had to make some pretty major modifications to the code, and now I can't see the 'Insert Record' option in the Server Behaviors panel when I've got my product_Insert.php page open in Dreamweaver.
I'm having trouble getting the image file names added to the database. THe images themselves are uploading just fine to my server, but the db isn't getting any info.
Here's my code... can anyone help me make the necessary modifications?
Thanks,
Arista
WA_DFP_SetupUploadStatusStruct("WA_UploadResult5");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFile("WA_UploadResult5", "img1", "", "images/products/", "".((isset($_FILES["img1"]))?$_FILES["img1"]["name"]:"") ."", "2", "[FileName]_[Increment]", "1000", "true", "0", "0");
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connection;
$WA_table = "product";
$WA_sessionName = "WADA_Insert_product";
$WA_redirectURL = "product_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "inv_number";
$WA_fieldNamesStr = "prod_name|prod_descrip|price|img1|img2|img3|img4|material_cat|form_cat|avail";
$WA_fieldValuesStr = "".((isset($_POST["prod_name"]))?$_POST["prod_name"]:"") ."" . "|" . "".((isset($_POST["prod_descrip"]))?$_POST["prod_descrip"]:"") ."" . "|" . "".((isset($_POST["price"]))?$_POST["price"]:"") ."" . "|" . "".((isset($_POST["img1"]))?$_POST["img1"]:"") ."" . "|" . "".((isset($_POST["img2"]))?$_POST["img2"]:"") ."" . "|" . "".((isset($_POST["img3"]))?$_POST["img3"]:"") ."" . "|" . "".((isset($_POST["img4"]))?$_POST["img4"]:"") ."" . "|" . "".((isset($_POST["material_cat"]))?$_POST["material_cat"]:"") ."" . "|" . "".((isset($_POST["form_cat"]))?$_POST["form_cat"]:"") ."" . "|" . "".((isset($_POST["avail"]))?$_POST["avail"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL";
$WA_connectionDB = $dbname;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
<head>
<title>Insert product</title>
<link href="WA_DataAssist/styles/Traditional_Moab.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="product_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Inventory Number</th>
<td class="WADADataTableCell"></td>
</tr>
<tr>
<th class="WADADataTableHeader">Item Name</th>
<td class="WADADataTableCell"><input type="text" name="prod_name" id="prod_name" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Item Description</th>
<td class="WADADataTableCell"><textarea name="prod_descrip" id="prod_descrip" cols="32"></textarea></td>
</tr>
<tr>
<th class="WADADataTableHeader">Price</th>
<td class="WADADataTableCell"><input type="text" name="price" id="price" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Main Image</th>
<input type="file" name="img1" id="img1" />
</td>
</tr>
<tr>
<th class="WADADataTableHeader">Image 2</th>
<td class="WADADataTableCell"><input type="file" name="upload2" id="img2" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image 3</th>
<td class="WADADataTableCell"><input type="text" name="img3" id="img3" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image 4</th>
<td class="WADADataTableCell"><input type="text" name="img4" id="img4" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Material Category</th>
<td class="WADADataTableCell"><input type="radio" name="material_cat" id="material_cat" value="ss" />
Sterling Silver<br />
<input type="radio" name="material_cat" id="material_cat" value="mm" />
Mixed Metal
<input type="radio" name="material_cat" id="material_cat" value="op" />
Opal</td>
</tr>
<tr>
<th class="WADADataTableHeader">Form Category</th>
<td class="WADADataTableCell"><input type="radio" name="form_cat" id="form_cat" value="br" />
Bracelets<br />
<input type="radio" name="form_cat" id="form_cat" value="nk" />
Necklaces & Pendants
<input type="radio" name="form_cat" id="form_cat" value="ot" />
Earrings & Other</td>
</tr>
<tr>
<th class="WADADataTableHeader">Qty Available</th>
<td class="WADADataTableCell"><input type="text" name="avail" id="avail" value="" size="2" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Moab/Traditional_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="product_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Moab/Traditional_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
To store the name of the uploaded file in the database, you need to modify the DataAssist insert record server behavior to use the Server File name variable created by DFP instead of the form binding.
For more details on this, see the "How to apply Digital File Pro to DataAssist Insert and Update pages" tutorial on the how to section of the DFP Support page:
digital-file-pro/
