JavaScript Error in CSS Sculptor
Thread began 11/22/2009 9:14 am by EvBarney383146 | Last modified 12/03/2009 6:27 pm by scarroll394484 | 2376 views | 7 replies |
EvBarney383146
Eric Meyer CSS Sculptor
Suddenly - I cannot use this plug-in at all. I have followed all instructions for clearing the cache - tried it on fresh sites in new root folders - uninstalled and reinstalled the extension and even, (incidentally - this had to do with something unrelated) reinstalled Dreamweaver.
Attached is error message I continue to get.
This is the worst time for this to happen - I need a solution ASAP - please!
Office Guy-172461
The error indicates that there is a problem with a Virtuosoft extension.
You might have to delete the config folder:
Solving problems with Dreamweaver
146/
EvBarney383146
Thanks for the quick reply - but I am on Windows 7 and - when I went looking for that folder, it was empty.
I've never noticed a conflict between ThemeDreamer and CSS Sculptor before - but because I needed to use CSS Sculptor NOW - I removed the plug-in for the time being. I'll need to be able to use in again though - and hope there is a solution other than playing musical plug-ins.
Brad Lawryk
I have the same problem and I only have DW Web Assist extensions and a couple PVII ones. DW was working on Friday - but not today.
Office Guy-172461
Try step 1:
146/
EvBarney383146,
As Office guy pointed out, the issues seams to be with a Virtuosoft
try removing the Virtuosoft extesnion from the extension manager.
The referenced in the error is likely in the Users configuration folder instead on the Dreamweaver Configuration folder.
Brad,
The "Initialize UI is not defined" error will be cleared by deleting the Dreamweaver Cache file from the user configuration folder as outlined in Office Guys post.
rpttrsn300655
remove themedreamer
In my case, removing the ThemeDreamer extension fixed this problem.
I don't remember this error before their latest update, and I've used both Sculptor and Themedreamer, so it may be just this latest version of ThemeDreamer.
scarroll394484
ThemeDreamer compatibility
FYI:
This issue has been fixed in ThemeDreamer version 0.6.2
