iRite table update problem
When I update a table inserted with iRite it adds "" to the properties of the table boarder, padding and spacing. How can I stop this?
is there any for formatting being applied to the initial value in the iRite instance.
try editing the iRite instance, and rebind the initial value. Click the lightning bolt next to initial value and reselect the recordset column, make sure the formatting drop down list is set to nothing.
