Sculptor Default
please, clean the TYPE in the Sculptor default. I go crazy always clean the already made CSS. Also in the DESIGN, put those lines away, please :-)
denis
denis
The TYPE is what you want it to be. If you don't like the default presets, then change them and save them. Change the TYPE and remove the lines. That's sort of the point of it.
You are in control of the DESIGN.
