"virtual" auto replacing "require_once" - why?
Thread began 11/21/2009 9:59 am by David CHnet.com | Last modified 11/21/2009 12:01 pm by David CHnet.com | 1666 views | 2 replies |
David CHnet.com
I switched to using a "testing server" in DW rather than jsut browsing the files direct from the server file system. Since then, code like this is being created and I don't understand why ...
<?php virtual("/WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
Because this already exists
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
Can someone please tell me why the WA wizards are now creating these "virtual" connections?
BTW the pages only work if I remove the "virtual" linesand leave in the "require_once" line.
Thanks :confused:
It does that to replicate the native Dreamweaver behavior based on your site settings. If you use root relative links, Dreamweaver recordsets and WA extensions use virtual instead of require_once. Just change your site settings to use page relative links and it will use require_once.
David CHnet.com
Perfect, that sorted it out, thanks :) :)
