trouble adding [charges] to calculation
Thread began 11/21/2009 5:18 am by jonojameskelly309911 | Last modified 11/24/2009 1:56 pm by Eric Mittman | 1430 views | 3 replies |
In my calculation column I am trying to add [Charges] into the calculation.
I have the following : [myvat] + [TotalPrice] + [Charges] - myvat is another calculation
This does not work, I just get a blank screen. If I change it to [myvat] + [Totalprice] it works fine but then leaves out the charges.
I have tried different ways of typing [Charges] like Charges, "Charges", ([Charges]) yet nothing works.
I can't just use the default total you get with Ecart (GrandTotal) as it doesn't include [myvat].
Is there anyway to add CHARGES to my calculation and get it to work?
I would really appreciate any help.
Many thanks.
A calculation is on a per item basis and can only include values from the cart columns. It will not be possible to include other charges from the cart in a calculated column. You could store the total vat for each item with a new column in the cart, then you could setup a charge rule that will be based on the subtotal of this vat column in your cart. Please explain a little about how you would like this working in the end and we can give you some pointers on how to get it that way.
Hi. What I have decided to do is the following:
<?php $vat = $pass->TotalColumn("myvat");
$delivery = $pass->GetCharges();
$subtotal = $pass->TotalColumn("TotalPrice");
$vatdelivery = $vat + $delivery + $subtotal;
echo number_format($vatdelivery,2);
It works great accept for when I use Universal email to send the mail with this code in it. Instead of showing the $vatdelivery amount it is blank. Should I try get this into a session variable or something?
That is exactly what you should do, storing this value in a session variable will ensure that you can get access to it in the email. Sometimes the scope of variables can be a tricky thing in php, but luckily using the session variables is easy way around this.
