editing menu after development
Thread began 11/21/2009 8:04 am by fraskos393357 | Last modified 11/21/2009 8:44 am by neilo | 716 views | 1 replies |
fraskos393357
Hello
Just a question. Let's say that i have finished the whole web development project for a client, and after a month he decides to add a menu item or a asubitem at the existing navigation.
How can i do this? is there a way to edit the menu items and t's subitems after creating a menu with menuwriter or i must re-create a whole new one from the beginning?
thanks
neilo
Yes - you would click to select the menu, and use the edit buttons that appear in the properties panel (inspector).
If you had your menu made on its own page, and 'included' in (SSI) on each page, then you would only need to edit that one instance of the menu whenever a client wanted to add something.
If you can't select the menu, try following Jason's advice at showthread.php?t=6023
