Go to Previous URL - problem
Thread began 11/21/2009 4:13 am by info195382 | Last modified 11/23/2009 2:30 pm by info195382 | 896 views | 2 replies |
info195382
I use the ASP/VbScript version of security assist and enabled the option "go to previous url (when exists)". But this does not work as intended ...
If I try to access a protected page (and I'm not logged in yet), I'm sent to the login page correctly, but after a succesfull login I'm always taken to the default redirect page. Never the previous page ...
Has anyone experienced the same problem or has a solution ?
Much appreciated.
Benny
he previous URL is passed as a Querystring variable.
For the login page to redirect to the previous page, the login form must pass the original querystring variables.
Set the forms action to:
action="<% If(Request.QueryString <> "")Then Response.Write(CStr(Request.ServerVariables("SCRIPT_NAME"))&"?"&Server.HTMLEncode(Request.QueryString)) Else Response.Write(CStr(Request.ServerVariables("SCRIPT_NAME"))) %>"
info195382
Yep, you ar so right !
thanks a million.
