Trigger Download with form submission
Thread began 11/20/2009 1:52 pm by takingchances6176651 | Last modified 11/23/2009 3:05 pm by Jason Byrnes | 2348 views | 5 replies |
I built a form with formbuilder and integrated UEmail. Everything works fine.
However, what I am wanting to be able to do is make it to when the customer fills out the form (which is validated) and clicks the submit button it triggers the form to be sent but also triggers a file download. Can this be done with digital file pro and if so, how would I go about doing it?
Yes, you can do this using Digital File pro.
You need to use the DFP Download File Server behavior.
Set the trigger to currant page submit.
You will need to supply the location on the server of the file to download and the file name.
Ok. I got that to work, but I did not like it becuase it doesn't take the user to the "thank you" page that I have set up for the form. It keeps the user on the same page without taking them to the thank you page but it does download.
I tried setting the download to trigger once the user is sent to the thank you page by the form. I used "download before page is loaded". However, it still never shows the thank you page.
How can I make it so that the user fills out the form, it sends them to the thank you page, and then automatically triggers the download? But I need for them to see the thank you page.
on the thank you page, add the Download behavior, set it to trigger on currant page submit.
Then add the following just before the </body> tag:
<form name="form1" method="post" action="<?php $_SERVER['PHP_SELF']?>?dl=true" style="visibility:hidden">
<label for="textfield"></label>
<input name="textfield" type="text" id="textfield" value="my val">
<label for="button"></label>
<input type="submit" name="button" id="button" value="Submit">
</form>
if (!window.location.search.substring(1)) {
document.form1.submit();
</script>
It's still not giving me the thank you page. It just downloads automatically but never shows the thank you page. You can go to download.php and fill out the form and see what I am talking about. Thanks so much for the help!
you have added the form from my previous reply inside the head of the program_download.php Page, you need to move that form so that it is just before the </body> tag at the end of the page.
