Include function with recordsets variable
Thread began 11/20/2009 2:17 am by austin_kyo371741 | Last modified 1/11/2010 1:53 pm by Jason Byrnes | 3134 views | 11 replies |
austin_kyo371741
I am trying to add include function with recordsets variable on page, this is the example of the script :
<?php include_once('sid=$row_RS['NO']_page.html);?>
Where $row_RS['NO'] is Recordsets variable,
I got error with this script... can some one fix this?
Dave BuchholzBeta Tester
What error message are you getting ?
Add this code to the top of the page to show error messages if you do not already have that set:
error_reporting(E_ALL);
ini_set('display_errors', '1');
austin_kyo371741
Originally Said By: Dave Buchholz
Hi Dave,
here is the error messages:
Parse error: parse error, unexpected T_STRING in c:\wamp\www\Page\pageinfo5.php on line 1082
This is the script on line 1082:
<td><?php include_once('sid=$row_RS['NO']_page.html);?></td>
How are you defining sid ?
austin_kyo371741
Actually sid is just part of the files name,i can also change it to <?php include_once('$row_RS['NO']_page.html);?> $row_RS['NO'] is the number which has been store into database table. for example if $row_RS['NO'] is 5, then it will include 5_page.html files
your syntax should be:
<?php include_once('sid='.$row_RS['NO'].'_page.html');?>
austin_kyo371741
Hi Jason,
Thanks alots, it works!!!
Zulian
Can you show me an example of this?
Hello Jason Byrnes & austin_kyo371741,
This is interesting, can anyone show me a real example of this. I also need my recordset details to have a friendly URL like below;
As you are using <?php include_once('sid='.$row_RS['NO'].'_page.html');?> , can I print my recordset detail as .html exention.
for eaxample, ?apple=apple to apple.html
Regards
sure, you can include an html page in your page page using the include once, if the value of $row_RS['NO'] is "apple", then the following code:
<?php include_once($row_RS['NO'].'.html');?>
will include the file:
"apple.html"
Zulian
How to get recordset name as page with .html extension
Dear Jason,
This is my php code where I wanted to make pagename with .html extension.
<a href="pages.php?page=<?php echo urlencode($row_rsGlobal['name']); ?>"><?php echo $row_rsGlobal['name']; ?></a>
I wanted <?php echo urlencode($row_rsGlobal['name']); ?>.html to be the name of the page.
so if $row_rsGlobal['name'] is webassist, my page should be webassist.html
How can I do this?
Thank you
Zulian
