CSS Sculptor 3 won't load
Thread began 11/19/2009 5:26 pm by 2007mg378555 | Last modified 12/11/2009 12:54 pm by Jason Byrnes | 2526 views | 4 replies |
2007mg378555
Every now and again CSS Sculptor stops loading and I need to perform a force quit. In the past, I uninstalled and reinstalled the add-on. That solution is no longer working. The specific error is:
"While executing onLoad in wacs_quickinsert.htm, the following JavaScript error(s) occured:
In file "wacs_quickinsert": initializeUI is not defined"
Can someone please help.
try deleting the Dreamweaver Cache file from the users configuration folder:
robert360150
Why do you keep telling people to delete the cache?
It does not work. It did not work for this post - or the other one that is "live".
This is very discouraging... how about a real fix?
Same error message - renamed the configuration file. Uninstalled all extensions, reloaded just CSS sculptor. Same error message.
They say a tool only fails when you really need it... now I really need this tool.
Very disappointed in San Diego, Robert
mark394741
Deleting cache file worked for me :)
I had the same error message which started after I saved a custom CCS design. I deleted the cache file and it began working again. I did have to re-enter my license key.
I have not encountered an instance of the "initializeUI is not defined" error where deleting the cache file does not resolve the problem. I have seen a few cases where the computer needed to be rebooted then have the cache file deleted.
I have started a support ticket so we can get this problem resolved for you though.
supporthistory.php?
