Yahoo Site Map error
When I use the submit for my site I get a site map error
Normally when you get a 403 error message from a browser it is because you are visiting a page that is restricted by the server. Please explain a little more about the steps you are taking and the result you get with these steps, also any additional info about the error in question would be very helpful like the URL that is giving you this error.
I am getting the same error - 403-forbidden...
What I am doing:
1. Using the WA Submit Site Map (part of Surveyer)
2. Selecting my sitemap XML from my site (also created in Surveyer)
3. Confirm that all search engines are selected and clicking OK
I get success results pages from all search engines EXCEPT Yahoo, from which I get the error page. (See attached image)
The URL that is failing is: ping?sitemap=http%3A%2F%2Fbozemanfigureskating.org%2Fsitemap.xml
Interestingly, if I click on the URL above (from within this forum) it seems to successfully get submitted.
Thanks for the help!
I have submitted a ticket for you on this issue, to check the status of the ticket or update it please login to WebAssist.com and visit your support history page.
