DataAssist sort
Thread began 11/19/2009 1:15 pm by chris373619 | Last modified 11/20/2009 12:53 pm by Jason Byrnes | 2866 views | 8 replies |
chris373619
DataAssist sort
I have a database and I need help on sorting. How do I sort something for the exact file name with the extension of the file. I just want the record to show if the file name is exact. But all the files have ".pdf" at the end. How do I get the sort to not look at the file extension.
neilo
You should be able to do this by double clicking the relevant Recordset in your bindings panel, and in the recordset (advanced, not simple) window that opens, select the relevant table from the 'Database items' section
Expand 'tables', select and expand the appropriate table, highlight the (Filename?) column you want to sort by and click the 'Order By' button.
Check the last line in the SQL window (scroll down to the bottom) to make sure you only have the 'ORDER by' code that you want. (It's easy to forget to remove a previous Order by).
Edit: Or just change the 'ORDER by' bit in the page php.
neilo
Best see this thread:
showthread.php?t=7555
chris373619
How does this get ride of the extension (.pdf) in the file name as a part of search criteria? In my database the file names are "filename.pdf". I only want the first bit of that to be the search criteria and to only show a record if the whole first part is equal to the record without the pdf.
I hope I explained that right. I did look at the link you posted but I didn't see how I could apply that to my situation.
Chris,
I think there is a little confusion here, the question you *asked was how to sort the recordset, the file extesnion wont effect recordset sorting. Sorting is the order in which the results are returned.
It looks like what you are really looking for is how to Search the database which is completely different kettle of fish.
since all of your files have the extesnion ".pdf" the simplest solution will be to append .pdf to the search string.
another way to go about it will be to use the replace function in your recordset:
SELECT REPLACE(filenameColumn, ".pdf", "") as stripedFileName FROM tblName
Get your search page to a point where it is working when you include the file extesnion in the search criteria, then post a copy of the page here, and I will let you know the modification to make so that it will work without the file extesnion in the search criteria.
chris373619
Sorry for the sort confusion.
I think this is good. I have it set to "begins with" but I wanted it to be = (without the .pdf).
Thanks for you help!
index.php.zip
Try changing line 50:
$WADbSearch1->addComparisonFromEdit("filename","S_filename","AND","Begins With",0);
$WADbSearch1->addComparisonFromEdit("REPLACE(filename, \".pdf\", \"\")","S_filename","AND","=",0);
chris373619
Works perfectly.
When I open DataAssit search Server Behavior it says the the code was hand coded. If I need to change something I would just need to fix this line after?
Yes, That is correct.
