Possible error
Thread began 11/19/2009 9:29 am by maurizio.melandri390100 | Last modified 11/25/2009 10:58 am by Eric Mittman | 1597 views | 5 replies |
Possible error
I tried to build a site to insert records in a table. The search page there is a dynamic menu and it works. I tried to include two dynamic menus on the inert page, but dhpc_tipo appears to be empty, while dhpc_descrizione_tipo becomes a text field instead of a menu.
dhpc_sigla is not editable.
Search.php
I can see the fields on the page you posted the link to, but I'm not sure exactly what the problem you are experiencing is. If you would like to make the text field on this page a select list then you can do so from withing DW. You can make a new select list and then just name it the same as your text field, then you can remove the text field.
If you are trying to do something else with the page or have a different problem please post back and let us know with a little more detail about what you are trying to accomplish and what you have done to get the current result.
I would build a page to insert a record. The fields "Type" and "Description Type" I wish that they were dynamic menu. I would take the data of dynamic menus in the table, however, are not valued.
The "dhpc_sigla" I asked "Given Assist" which was a text field, however, is not usable.
tables.txt
Thank you for trying to explain this to me a little further but I'm just not following along. I'm not understanding what you hope to accomplish as an end result and how that compares to what you have now.
When using DataAssist Search you specify the names of the fields that will hold the values you are searching on. If you have a text field that you would like to be a select list that holds values from a recordset you can add in the select list to the page, then name it the same as the text field. To make it dynamic you would need to first create the recordset then using the property inspector you would click on the dynamic button and specify the recordset and the values from that recordset that you would like to populate the select list.
Page [url]http://www.doctorhousepc.com/admin/Insert.php[\url]
In the fields dhpc_tipo and dhpc_descrizione_tipo I specified a date that will be two menus Assist dinamici.In At first I tried to load the menus from the tables dhpc_descrizione_tipo and type. Then I tried to load from the table dhpc_prodotti. In both cases the result you see it.
Dhpc_sigla MUST be a field of input.
Record set: schede
My apologies but I'm having a difficult time understanding the nature of the issue you are experiencing. I visited the site and can see the fields there but I'm not sure what is not working correctly for you. Are you trying to populate the select list on this page from a recordset? If so you need to create the recordset first, then you can select the list on the page and use the property inspector to set the dynamic values to the recordset you have created.
I'm just not sure if this is the problem you are experiencing or if the issue is something else.
