eCart checkout wizard
Thread began 11/18/2009 9:40 pm by david331670 | Last modified 11/19/2009 2:22 pm by Jason Byrnes | 2867 views | 7 replies |
david331670
How can I edit or alter the eCart Checkout wizard information?
I have created the checkout for my testing server at localhost:8888/ ( with much hair pulling). Do I need to go through that process again to load to my web server with my website address? or is it easily changed in source code. If so do I just "find and change the Localhost "href" to my actual web site address as well as change the "Checkout Wizards" created pages including payPal express pages and the WA_eCart folder
OR BETTER YET
is there a way to view and edit the wizard info page by page?? I should be so lucky
I am using PayPal "Payflow Pro"
Appreciate your assistance in advance-
FYI Brisbane Australia time difference
David
The checkout pages created for payflow pro should not have the localhost domain referenced anywhere. There should be any changes that need to be made to the checkout pages to test them on your remote server.
david331670
eCart checkout Wizard
Thank you for your reply
This is my first cart with ecart.
Getting started guide , page 125, has "site address" as local host, I assumed this was what was required for my "Local" testing server.
I now assume I put my actual site address here as well as the 2 PayPal express "order confirmation-Cancel URL's.
Does this mean I need to recreate the pages or can I alter the "href" in the source code for those pages.
Thank again
David
You alter the href in the source code for those pages.
david331670
ecart checkout Wizard
Thank you very much
you're welcome.
david331670
eCart
Can you save the Checkout Wizard"s pages or edit the pages once completed?
At the moment you need to complete each page before you can see what the next one holds.
If you dont have all the info you need, you need to restart the whole exercise again every time you change anything in any part of the setup.
It would also be nice if you could advance to the end, page by page without filling in each page to preview and instead of just finish or cancel buttons at the end a "Save" button so you can edit and finish later.
Regards
David
The check wizard settings cannot be saved.
Once the checkout pages have been created by the wizard, you can edit the server behaviors that are applied to the pages to modify the settings.
