Warning: require_once(WA_ValidationToolkit/WAVT_Scripts_PHP.php)
Thread began 11/18/2009 8:59 am by takingchances6176651 | Last modified 11/19/2009 4:43 pm by Jason Byrnes | 2980 views | 5 replies |
I get the following message when trying to access the page. www.planswiftfreetrial.com.contact.php
Any ideas?
Warning: require_once(WA_ValidationToolkit/WAVT_Scripts_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/b/r/i/brianalbey/html/free/contact.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'WA_ValidationToolkit/WAVT_Scripts_PHP.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/b/r/i/brianalbey/html/free/contact.php on line
Office Guy-172461
Did you remember to upload all of the support folders?
I was thinking about that. Do you happen to know what all support folders I need to upload? Thank you for your help!! It is greatly appreciated
** I was watching the video tutorial and when it goes to the "general tab" and then goes to the "workflow section" it says to select the "Button: Submit Pressed". When I use the dropdown box by trigger I do not have the "Button: Submit Pressed" option to select? I only have (any form post), (before page load), and (current page submit). Those are the ONLY options I have to choose from? Why is that?
You need to upload the WA_ValidationToolkit folder.
Is the WA_ValidationToolkit folder a custom folder that has site specific information in it? The reason I ask is I have that folder on one of my other sites that I made from UE and I thought UE made the folder for me when I completed the extension just like it does the UE folder. However, it did not make it for this new site. So can I copy the WA_ValidationToolkit folder from the other site and place it on this new site?
no the WA_ValidationToolkit folder is not site specific.
It gets created by The validation Toolkit or CSS Form builder Extension.
It sounds like you are using a form from the contact form solution pack? If so, use the WA_ValidationToolkit folder from the original contact form solution pack download.
