Noob - blank page after HTML Editor install
Thread began 11/17/2009 11:05 pm by pete268226 | Last modified 11/20/2009 12:59 pm by Jason Byrnes | 1795 views | 9 replies |
pete268226
OK, I don't get it. I installed the extention with no trouble. Ran a basic config with no file managment. Uploaded the new page (Products_Insert.php from PowerStore2) and the HTML_Editor directory that included the custom file created.
Refreshed and...! The page is blank.
I am sure that I've just missed something simple - but cannot find it in any of the documentation. Any ideas?
Thanks,
Pete
When a page displays blank, it means there is a php error occurring, but error reporting has been turned off so it is not being displayed.
add the following code at line 1 of the page to enable error reporting:
error_reporting
(E_ALL);
pete268226
Hi Jason,
Here is the resulting error:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/html/new/Admin/Products_Update.php:6) in /var/www/html/new/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
I would appear that I'm somehow dealing with two headers...?
Thanks,
Pete
That error basically means that there is some output to the page before the session start function is used.
according toi the error:
the ouptput is arund line 5 or 6.
Usually it is either a blank line between ending php code block and a starting php code block:
[php]
[/php
or it can be a space after the end of the php code block:
For more details, see the following
http://www.ipvac.com/kb/entry/148/
pete268226
OK, so that seemed to deal with the multiple headers issue. I re-installed the HTML editor on my form item and now receive this error:
"Fatal error: Cannot redeclare createrichtexteditor() (previously declared in /var/www/html/new/HTMLEditor/WARichEditorPHP.php:3) in /var/www/html/new/WA_iRite/WARichEditorPHP.php on line 16"
Again, any help would be appreciated,
Pete
sounds like the line:
<?php require_once("HTMLEditor/WARichEditorPHP.php"); ?>
is on the page more than once.
pete268226
PowerStore provides iRite while my addition requires HTMLEditor. There were two calls for that .js file - one from each. I eliminated the line that called for the iRite version.
I receive no errors but the HTML editor does not show up on the text-box - it's just a blank white space that I cannot click into. It seems to have an id of "xEditingArea".
I did upload the .js file that was generated - did I miss another upload?
On a broader note, I think part of why I'm confused is that the smaller WA apps are utilized within larger solutions (like HTML Editor inside of PowerStore2) but there is little documentation on how to modify what exists within the provided framework. All the tutorials presume that one wishes to create something new but doesn't discuss how to take further that which is provided. It seems to be a common theme - everyone appreciates the function of the software without having to become coders, and the advice needed is often just a nudge in the right direction. (Just my 2ยข worth of observation...)
Thanks,
Pete
Sorry I missed the part where you said this was a power store page.
The Problem is that you cannot have an iRite instance on the page and an HTML Editor Instance at the same time.
before you can add an HTML Editor Instance to the page, you need to update the iRite instances that are already there.
For each iRite Instance, select it in design view. In the property Inspector, click the edit button.
From the editor preset list, select Default File manager Enabled.
then click OK, for the first one, the site preferences will open, select the enable file management option, then click the folder icon next to image upload path and select the the Images/Upload folder.
Once you have updated all of the iRite instances, find the following line:
<?php require_once("../WA_iRite/WARichEditorPHP.php"); ?>
and comment it out:
<?php //require_once("../WA_iRite/WARichEditorPHP.php"); ?>
then test the page.
you can then add in your new form element and apply the HTML Editor to it.
pete268226
Solved!
Thanks Jason - the update worked well. I also had to reset my server behaviours and it's working. Thanks (again!)
-Pete
excellent, glade to hear it.
