Problem aligning text to vertical axis
Thread began 11/17/2009 3:51 am by freiheit | Last modified 11/18/2009 6:03 am by freiheit | 1590 views | 2 replies |
freiheit
I used CSS Sculptor to insert to my layout 4 collapsible panels.
I gave each one of them a height of 30 pixel but i have problem to align the text verticaly.
For some reason when i edit the rule ''.CollapsiblePanelTab" in block field,the horizontal alignment works normaly , but the vertical alignment in css properties just dont want to work.
What can i do to align verticaly to the center of the div box the text?
Justin Nemeth
Vertical alignment is not going to work like horizontal in CSS unfortunately. What I would do is remove the height, and instead give a top and bottom padding value (likely 15px for each in your case). That will effectively align the text vertically.
-justin
freiheit
Originally Said By: Justin Nemeth
-justin
It worked perfectly :)
Thank you !
