User Forms for 2 Sets of Users
Thread began 11/16/2009 4:51 pm by rob294118 | Last modified 11/18/2009 5:24 pm by Eric Mittman | 1189 views | 3 replies |
rob294118
I'm looking to somehow modify the registration, user profile, login, logout forms.
I have 2 user tables one for customers and one for vendors. How can I modify all the forms to use one set of forms if you're a customer and one set of forms if you're a vendor? Some sort of variable and then IF statements maybe set on the pages?
Customer Login Vendor Login
Thanks.
Do you need to have completely different forms for registering and logging in? If so how do you determine which form to show the user?
You are rite about how you could get them both on a single page, you would use some if statements to show one versus the other, but how do you make this determination?
Alternatively you can create a different set of user pages with the Security Assist wizard. Please post back with some more info about how you will have this setup and we will help you out with whatever we can.
rob294118
I need to have different fields on the registration and profile forms.
I have 2 user tables, usercustomers and usersdesigners.
I was going to have 2 links on a menu...one for Customer Login and one for Designer Login. Once a user selects "Customer Login" or "Designer Login" I want to set a variable (customer or designer).
I want the user_profile to display either user_profile_customer or user_profile_designer depending on the variable set.
Ok, to setup the variable you must ensure that a user clicks on the link. In the link you should add a URL parameter, you can call it login and set it 1 for the regular user and 2 for the designers. It would look like this:
html:
<a href="login.php?login=1>Customer Login</a>
Then on the top of the login page you can set a session variable based on the value of this URL parameter. You can call it the same, you should also assume a default of customer in case the user goes directly to this login page. That code would look like this:
if(!session_id()) session_start();
if(isset($_GET['login']) && $_GET['login'] == 2){
   $_SESSION['login'] = 2;
}else{
   $_SESSION['login'] = 1;
If you have both forms on this page you can show one or the other like this:
if($_SESSION['login'] == 1){ //if the user is a customer then display the customer login
   //customer login form goes here
}else if($_SESSION['login'] == 2){ // if they are a designer then display that login
  //designer login form goes here
You can use this same logic for other pages that you would like to display one thing versus another. One other thing to check will be the names of your submit buttons for these forms and the triggers for the login. You will need to ensure that you have unique names and that the server behaviors are only triggered on the submission of the correct form.
