WAVT_Scripts_PHP.php on line 544
The following error shows up after I fill in the registration form created with FB and given a server behavior of input with DA.
"Warning: preg_match() [function.preg-match]: Delimiter must not be alphanumeric or backslash in /var/www/zona/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 544
Warning: Cannot modify header information - headers already sent by (output started at /var/www/zona/WA_ValidationToolkit/WAVT_Scripts_PHP.php:544) in /var/www/zona/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 71"
The form originally worked well and added the records to the database. I then made changes to then recreated the form with some modifications and applied the behavior again. That's when this showed.
I have uploaded the scripts.php and the registrationform.php in case you need to see the code.
jc
